When I was fixing my PC, I had a problem compatibility issue which sounded like
"Some Intel Z87 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs."
Is that a serious problem and should I be concerned? Thanks!
most should be updated at the factory now so I don't think there will be a problem
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/425491-help-with-pcpartpicker/#findComment-5710469
Nope, usually the latest BIOS will be shipped with your board. If not, a simple flash with a USB stick will do the trick. I recommend a Z97 board though.
https://linustechtips.com/topic/425491-help-with-pcpartpicker/#findComment-5710470
