SPDIF problems.
I have an audio problem with youtube mainly. When ever i search for a video i cant hear the audio but i can hear the audio from videos that i watch from my sub box, when i click my audio output it is playing through SPDIF. Any help will be appreciated !
https://linustechtips.com/topic/4254-spdif-problems/
Generally you do not want the SPDIF to be selected as your defauly audio device. You need to go to control panel->sound-> Find your output device(generally windows calls it speakers or headphones) and select that as your default audio device.
Cant put my speakers as default device, but everything works when i use headphones or selected song/s
https://linustechtips.com/topic/4254-spdif-problems/#findComment-54897
