I have a DGN2000 Netgear router right now and it sucks. To top that off the wireless is going bad constantly loosing connection and range is less than 50ft. So my resolution was to buy an access point, a small one the would just cover the house and nothing else then i decided it would be best to get the (UniFi AP Long Range) and cover my house, backyard, front yard and more. But i only have one question, i dont want to have a green thing sticking out of my living room ceiling so if i stick this in my atic even though its up about another 30ft from were im going to be using a device will it still work properly.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/42488-networking-question/
The signal from a router can usually travel up and down through a house quite easily as between floors is usually only a bit of wood.
Also perhaps post this in the networking section!
CPU: AMD FX-8350 | CPU Cooler: H80i | Motherboard: Asus M5A99FX PRO R2.0 | RAM: 8GB Kingston Beast 1866MHz
Case: Define R4 | GPU: Gigabyte GTX 780ti | PSU: Corsair CX600M | SSD: 250GB Samsung 840 EVO
.... and a Partridge in a pear tree!
https://linustechtips.com/topic/42488-networking-question/#findComment-553300
Ye if you can use ethernet or powerline plugs or even get some of those powerline access points around the house because they do not need any more wiring and they work well if you have a few round the house.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/42488-networking-question/#findComment-563038
