I would go with the I5 build as that cpu will last you for a long time meaning you will only require gpu upgrades where as with the FX6300 build that cpu will not last you very long.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/424734-help-me-with-my-build/#findComment-5701235
I'd save up more and go i5 + 280x.
The 280x is leaps ahead of the 270x, but the FX6300 is such a useless chip nowadays that you'll have to upgrade it pretty quickly.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/424734-help-me-with-my-build/#findComment-5701257
i5 simply because amd cpus are crap and save a bit more for the 280x, the 270x won't last you very long before you need to upgrade, but the 280x is decent enough.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202137 this is an amazing deal if you ask me
https://linustechtips.com/topic/424734-help-me-with-my-build/#findComment-5701269
Save 6$ more.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($166.95 @ SuperBiiz)
Motherboard: Asus Z87-A (NFC Express Edition) ATX LGA1150 Motherboard ($59.00 @ Newegg)
Memory: Kingston HyperX Fury Blue 4GB (1 x 4GB) DDR3-1866 Memory ($17.89 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($43.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 280X 3GB Video Card ($189.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($29.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($29.99 @ NCIX US)
Total: $555.69
Generated by PCPartPicker 2015-08-06 14:52 EDT-0400
https://linustechtips.com/topic/424734-help-me-with-my-build/#findComment-5701476
Save 6$ more.
Total: $555.69
Thank you for trying to help me with that build, but I don't use rebates on my build, so that build would be a lot more expensive
I want a gaming PC that can run all game 1080p 60FPS!! But unfortunately, I don't have money and I'm too young to have a job XD
https://linustechtips.com/topic/424734-help-me-with-my-build/#findComment-5701529
Promo codes to the rescue.
Total: $555.69
https://linustechtips.com/topic/424734-help-me-with-my-build/#findComment-5701964
Normally I would say go AMD as I prefer their chips (even though in the big scheme of things you will never get the performance from them that you can from an intel chip). That said in this case it's a no brainer to go Intel. The AMD chip you mentioned is way behind the boat in terms of specs though the video card you chose is decent enough. Right now until AMD brings out their new chips I wouldn't be buying much from them as socket AM3's days are numbered. I personally am a big fan of the A10 Kaveri APUs but they still aren't in the same class as a top end AMD AM3 chip. At least not yet.
https://linustechtips.com/topic/424734-help-me-with-my-build/#findComment-5703379
