Guys
I want to change my case which is at the mo is a Carbide 400R, its  to bloody big and i want to downsize but leave some room for expansion.
It needs to be ATX compatible and accommodate a EVGA 780 SC ACX card which will soon be replaced with a EVGA 980ti ACX i have no intention to use SLi
My cooler (Aska Venom  Voodo) is a bit large and i want to use it as its excelent
I am using a Corsar 760i PSU
2 x seagate 1TBHDD
1 x Intel 730SSD
I dont need any colour lighting shit
cheers
https://linustechtips.com/topic/424588-replacement-case/
googled it, looked kind like a kind of "normal" sized case also if you didnt live in the UK i would have traded you my case, a Zalman GT1000 its nice but its not aveilable anymore :/ also it weighs 12.5KG... well i dont know what to recoment , it looks like you have only slightly more then the required vertical hight but silghtly more then the absolute minimum in length, and width seemed to be also about "normal" so i dont think your getting much smaller then that if your not going with a box case so i have no idea, maby mount it on the wall or something then youll have all the room you want for that cooler
Builds:
https://linustechtips.com/topic/424588-replacement-case/#findComment-5699549
Appreciate the reply, I could live with what i've got, but the dam thing wont squeeze into my computer table both length and width, drives the mrs wild!..if i hung it on the wall (good idea by the way)..my divorse papers would already be counter signed!
https://linustechtips.com/topic/424588-replacement-case/#findComment-5699686
well take a look at some fractal cases i think some may be a tad smaller :)
Builds:
https://linustechtips.com/topic/424588-replacement-case/#findComment-5699693
