the motherboard will see it as just one fan, so both will be running at the same speed.  they should be running at the same speed as one fan, but they will draw more power, so you need to be careful if they are high power draw fans.
Its better suited for things like front case fans, that all should be running at the same speed.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/423600-fan-splitters-concerns/#findComment-5688231
Mobo will see single fan. With splitters you generally have to guess or test which head is the primary one. With hubs its marked. But usually you use splitters to two identical fans so it doesn't matter which is the one to be monitored and/or controlled.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/423600-fan-splitters-concerns/#findComment-5688385
Or will it confuse it for 1 fan and so each fan has to share the volts which would slow them down?
Adding more fans in parallel doesn't change the voltage drop across them.
i5-4690K@4.5 GHz // Asus Z87-Pro // HyperX Fury 8GB DDR3-1600 // Crucial BX100 250GB // Sapphire Nitro R9 390 // EVGA SuperNOVA 750W G2 // Fractal Design Define S // be quiet! Pure Rock & Pure Wings 2 // BenQ XL2730Z // Corsair Vengeance K70 // Logitech G403 Wireless // Sennheiser HD 598 SE
https://linustechtips.com/topic/423600-fan-splitters-concerns/#findComment-5689240
If I use a fan splitter cable on my motherboard, will the motherboard know that I'm using it? Or will it confuse it for 1 fan and so each fan has to share the volts which would slow them down?
For example, i have 2 AP121s that run at max 1500 RPM. Almost all of the time, the fan control software runs them at the RPM i want, but ocasionally, for like a second, i see fan speed 3000 RPM, so ocasionally and briefly my mobo adds the RPMs of both fans, but in practice it works great, and i'm using a 1 dollar 3 pin splitter, and another for the top fans, and a PWM for the other rad fans, and they all work great.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/423600-fan-splitters-concerns/#findComment-5689401
