Is there any reason to go for more than one loop in one system? One pump is enough for CPU + 4 GPU?
31366_3_maingear_unleashes_liquid_chille
other than the fact 4way sli and cfx is a really bad idea.. one pump with sufficient head pressure will be fine. the additional gpus don't out any more load on the pump as water is still flowing with very little restriction.
separate loops just stop hot components making the whole loop hotter than needed. but sufficient radiator surface area and fans will overcome that
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/423592-few-simple-questions/#findComment-5688001
the reason you see seperate loops for the cpu and gpus in a fully setup custom loop is to help keep temperatures separate.
If you have 3x  390X's running overclocked, then they are going to heat up the loop, potentially increasing the temp on the cpu, stopping you from overclocking it as far, or just getting higher temperatures.
If you separate the two loops, suddenly, you're all crystal.
The most ideal situation, but the most stupid, money consuming, and space taking solution would be an individual loop for each item, keeping all temps separate.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/423592-few-simple-questions/#findComment-5688013
so, different pumps has different head pressures? Which one is the good one?
I'm no expert in the field and am asking questions about my setup too, but basically when it comes to pumps avoid cheap and buy branded and you should be OK.
https://linustechtips.com/topic/423592-few-simple-questions/#findComment-5688023
Man i love that gfx cable management!
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
https://linustechtips.com/topic/423592-few-simple-questions/#findComment-5688069
