since its plastic in a most likely metal case, its most likely screwed in or riveted. just break the rivets
edit: a quick look at the product page says they are removable?
​The hard drive cages are the bay is not atleast to my knowledge all of it is rivets
https://linustechtips.com/topic/423185-case-drive-cages/#findComment-5682600
you can unscrew it from the bottom
The HDD cages are completely modular and can be arranged in any configuration you like. They can be installed on top of each other, hung under the 5.25″ bays, or even separated with one under the 5.25″ bays and one at the bottom. If you decide to install a radiator at the front of the case, you will need to install the cage(s) in the rear most location, or simply leave them out all together. The sky is the limit as to how you can configure the 3.5″ cages. Removing the cages requires accessing the bottom of the case to gain access to the screws that hold the cage’s base plates in place. The included user’s manual will lead you to believe the cages can be removed by just sliding them off their base plate, but the case’s lower frame rail will block you from removing them this way.
https://linustechtips.com/topic/423185-case-drive-cages/#findComment-5682615
They're modular HDD cages not riveted in place on the 760T
Sorry im talking about the 5.25 in bays pictured here http://imagescdn.tweaktown.com/content/6/1/6194_15_corsair_graphite_760t_full_tower_chassis_review.jpg
https://linustechtips.com/topic/423185-case-drive-cages/#findComment-5682686
Oh ok those are pretty easy you will need to take off the front panel to get access to the rivets and drill them out with say a 1/8" drill bit, also the metal underneath is usually not finished where t overlaps of the rivets so you might need to get a paint marker or metal paint to match the black.
https://linustechtips.com/topic/423185-case-drive-cages/#findComment-5682706
https://linustechtips.com/topic/423185-case-drive-cages/#findComment-5682707
the cage is riveted But also a part of the fan housing in the front its one long piece
Also i cant seep to find how to undo the front panel to get access to the rivets
https://linustechtips.com/topic/423185-case-drive-cages/#findComment-5682885
There are plastic tabs on both sides of the case you need to force to bend and push the front panel to remove it, it can be a bit tricky:
http://i.imgur.com/XcSfPF0.jpg
https://linustechtips.com/topic/423185-case-drive-cages/#findComment-5682940
