Okay I've been messing with my setup in my 760T and I need help. I currently have my H110I mounted at the front with push pull set up. The pushing fans are 140s air flow as I didn't have anything else with LEDs. The rad fans are 140s SPs. Then on the top of the case I have the two AF 140s that came with the case as exhaust. I have no fan on the back my gpu is running hotter then id like. Would it be better to swap the 2 140s on top. Move one to the rear. Then put some old 120s on top? I'm trying to get the airflow from the front back up and over the gpu then moving out the back. I can also mount a 120mm on the floor of the case to push air up if that's needed?
https://linustechtips.com/topic/423096-760t-airflow-help/
