No... A 7970 is neck to neck with the 770.
If you're talking about crossfire, 2 7950's is like a 780.
2 7970's is more powerful than a 780.
I'm not talking about a stock 780 btw. You should always be overclocking your gpus as much as you can.
I haven't been able to oc my 6870 because the core voltage is locked on it, buit I did have my gt 520 before oc'd.
i5-4670k 4.5 Ghz 1.25v | Gigabyte Z87X-UD3H | 4x4 Gigs of Corsair Vengeance Pro 1600Mhz | Gigabyte 980 Ti Reference 1503 Core/ 7796 Effective Memory | H100i w/stock fans | EVGA Supernova 1000w G1 | Samsung 840 120Gb SSD | Seagate Barracuda 2TB 7200RPM | Corsair Force LX 128Gb SSD | Fractal Design Arc Midi R2 | DT 990 Pro 250Ohm | Blue Snowball | Logitech G710+ | Logitech G600 | Acer H236HL BID x 3
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550300
Well, be glad you're getting a 7970.
Both the 7970/7950 are great overclockers.
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550315
I'm very glad you were able to include squeeze the 7970 into it.
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550318
Where would the h100i be put on the 300r?
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550326
Like this:
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550332
Like this:
ah ok XD that answers the question perfectly.
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550334
I really do like the very friendly responses and the help I've gotten on this.
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550336
On the bottom of the pcpartpicker it says PNY 8GB (2 x 4GB) DDR3-1866 Memory operating voltage of 1.65V exceeds the Intel Haswell CPU recommended
Also still need help on this, it confuses me.
https://linustechtips.com/topic/42272-need-help/page/2/#findComment-550337
