Issues removing malware (SafeFinder)
Solved by Chronos5618,
Though I know this name is cursed on the forums, I shall utter it anyway (then go purify my body in a vat of holy water)- Norton Power Eraser has helped me out in sticky situations like yours, where other software has failed. Definitely worth a shot (and fairly sure you can put it on a usb from another computer if downloading it is an issue). Another thing- have you looked to uninstall it from the control panel. Sometimes (though not often) it can be as simple as that.
