I'm about to build another rig, and my GPUs, two R9 Fury Tri-Xs, are known to be some of the longest cards on the market (30.5 cm). So can I fit two of them in a NZXT H440 without having to remove the drive cage?
"The REVISED Companion Cube, v2.1" - "1440p, lock on." Discover it by clicking here.   // Peripherals - Corsair Strafe RGB  + Steelseries Rival
CPU - i7-6700k // Motherboard - ASRock Z170 Extreme 6+ // CPU Cooler - Corsair H100i GTX // Memory - 16GB HyperX Fury DDR4-2133 (2x8GB) // Storage - Samsung 850 EVO 120GB + Seagate Barracuda 1TB // Graphics - Crossfire Sapphire R9 Fury Tri-X // PSU -  EVGA SuperNova G2 850W // Case - Corsair Carbide Air 540 (Steel) // Devices - iPhone 6 Plus, Macbook Pro //
https://linustechtips.com/topic/422567-will-my-gpu-fit/
It appears not.
Sig under construction.
https://linustechtips.com/topic/422567-will-my-gpu-fit/#findComment-5674355
No, you would need to remove the cage in order to fit them in. 30.5cm comes out to be 305mm. With the drive cage in, you get 294mm and without it, 406.2mm.
https://linustechtips.com/topic/422567-will-my-gpu-fit/#findComment-5674356
It appears not.
Crikey that's unfortunate, good thing it appears that all you have to do is remove the drive sleds instead of taking out the cage.
https://linustechtips.com/topic/422567-will-my-gpu-fit/#findComment-5676209
