I bought some extra intake fans but one of the fans only came with 3 screws, is it safe to mount the fan with only 3 screws?
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/422163-fan-mounting/
I think it's safe. I got a fan or two with only two screws in a diagonal pattern. But make sure you have sound dampeners like a rubber edge so it wouldn't rattle.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
https://linustechtips.com/topic/422163-fan-mounting/#findComment-5669209
Thank you but the fans I bought were just cheap standard quiet fans and it's in a NZXT S340 so I will probably just lower the RPM and hope for the best if not then I will just mod the fans
        Setup
https://linustechtips.com/topic/422163-fan-mounting/#findComment-5669305
It will be fine. As long as the mounting point is flat 3 screws is plenty. Don't crank them down to hard tho as it will cause the fan to bow and then you will get annoying rattle's. Just make sure all 3 are snug and you will be fine.
Or, you can always find an old PC and take the screws out of it. Fan screws have been standard since forever.
https://linustechtips.com/topic/422163-fan-mounting/#findComment-5669566
What you should really do, is RMA it, more so if you haven't open screw bag yet. Fans always include 3 screws and you pay to get all what package is suppose to include. There's no point to take that kind of service from anyone.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/422163-fan-mounting/#findComment-5677954
Yeah but I already opened everything and it's not that bad I have 3 screws in and I can't hear a single rattle even though it doesn't have rubber on the mounting so I'm contempt with it and I could easily buy a screw.
        Setup
https://linustechtips.com/topic/422163-fan-mounting/#findComment-5679884
You could bring one of the screw and look for it over at your local hardware store. Make sure you get the right size and threading though.
https://linustechtips.com/topic/422163-fan-mounting/#findComment-5684991
