ppl claim ID 10mm OD 19mm is the best for flowrate, aesthetics and easiest to manage
but in the end it doesnt matter much
Pal what size fitting and which type of fitting will I need for http://www.performance-pcs.com/primochill-1-2in-rigid-petg-tubing-36in-clear-4-pack.html
https://linustechtips.com/topic/422059-size-help/#findComment-5668387
10MM (1/2) its for 3/8 1/2
basicly u get fittings for the size of ur tubing, thats all, if the tubing is 3/8 1/2 u need those fittings too for it, u could stretch it on bigger fittings but yeah, best to just get proper fittings
And okay so if I send two tubes from reservoir
First tube to radiator 1 and the other second tube to radiator 2
And rad1 goes to Cpu
Rad 2 goes to gpu and when those are going back to the res I can't put both
So if I put those tubes in this fitting http://www.performance-pcs.com/bitspower-deep-blood-red-y-block-with-triple-rotary-ig1-4.html#Additional-Information
And send one tube in the other side to red again will my loop work
How does the fitting work the triple whatever
Sorry for so many questions
Cause it's my first time
https://linustechtips.com/topic/422059-size-help/#findComment-5668445
