Help finding a fitting cpu cooler
Honestly, you'd probably be good with just a hyper 212 or something,=.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
this case?
What case..?
Well since you have a microATX I felt compelled of course to find the biggest possible cooler. A friend of mine used this on his micro but his is flat mounted as oppsed to side mounted. Im a fan of overkill so if you have the case room and the budget. It worked great for him.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018&cm_re=cpu_cooler_am3-_-35-608-018-_-Product
Praise Gaben
