Well, in idling and what not almost any gpu can do that. Assuming you also mean the monitors are 1080p, you probably won't be maxing every game with 60fps, but you'll definitely do really well.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/421835-980ti-help/#findComment-5665401
Not sure about that, but I do know it supports 4 monitors native
Command Center:
Case: Corsair 900D; PSU: Corsair AX1200i; Mobo: ASUS Rampage IV Black Edition; CPU: i7-3970x; CPU Cooler: Corsair H100i; GPU: 2x ASUS DCII GTX780Ti OC; RAM: Corsair Dominator Platinum 64GB (8x8) 2133MHz CL9; Speaker: Logitech Z2300; HDD 1: Samsung 840 EVO 500GB; HDD 2: 2x Samsung 540 EVO 500GB (Raid 0); HDD 3: 2x Seagate Barracuda 3TB (Raid 0); Monitor 1: LG 42" LED TV; Monitor 2: BenQ XL2420TE; Headphones 1: Denon AH-D7000Headphones 2Audio-Technica AD1000PRMHeadphones 3Sennheiser Momentum Over-EarHeadsetSteelseries Siberia Elite; Keyboard: Corsair Strafe RBG; Mouse: Steelseries Rival 300; Other: Macbook Pro 15 Retina (Mid-2014), PlayStation 4, Nexus 7 32GB (2014), iPhone 6 64GB, Samsung Galaxy S6 64GB
https://linustechtips.com/topic/421835-980ti-help/#findComment-5665407
Yeah, All of the monitors are 1080p.
Just look up some 4k benchmarks to be sure, although 3x1080p is about 3K so it'd be a little less demanding.
https://linustechtips.com/topic/421835-980ti-help/#findComment-5665432
