First option right beside the GPU is where most people put it you can also mount it to the rear of the case on the inside right in front of the GPU which is also an option.
hard because windowed case and it would be tricky with the clearance.
P.S thank you for your activity on the forms I have seen a lot of you recently same with oshino
https://linustechtips.com/topic/421823-res-help-please/#findComment-5665302
NP  ;)
If ypu plan to mount it beside the GPU's I would suggest to move it slightly to the right so it doesn't cover the grommets and you have a solid piece of metal to bolt it in place.
https://linustechtips.com/topic/421823-res-help-please/#findComment-5665352
Yeah I'd drill some holes too. Btw, what is that radiator, it be sexy af.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/421823-res-help-please/#findComment-5665360
