So I've been slowly upping the overclock on some of my parts and I'm worried that I may be taxing the power supply to far, and would love to know what the rough limit would be.
You can check all my specs in my sig, but pretty much I have dual GTX 780s and a 4770K on a 750W Silver PSU from Silverstone, and running three HDDs and a SSD.
I think I may already be pushing it a bit hard, but if anyone could let me know that would be great. I've overclocked my GPUs and wanted to do this before heading to the CPU side.
Cheers
Desktop Build
CPU: Intel Core i7-4770k
CPU Cooler: CoolerMaster Hyper 212X
Motherboard: ASUS Maximus VI Hero
RAM: Corsair Vengeance Pro 1866MHz - 16GB
GPU: ASUS GeForce GTX 780 - 3GB, MSI GeForce GTX 780 - 3GB
Storage: Samsung 840 Pro - 128GB, Western Digital Blue - 1TB, Seagate Barracuda - 1TB, Seagate Barracuda - 3TB
PSU: Silverstone Strider Plus 750W
Display(s): Dell Ultrasharp 27" (2560 x 1440)
Keyboard: Razer BlackWidow Ultimate 2014
Mouse: Logitech G502
Operating System: Windows 8.1
Laptop
Current
CPU: Intel Core i7-4710HQ
RAM: 16GB
GPU: Nvidia GTX 970M
Storage: Samsung 840 EVO - 250GB, Hitachi Travelstar 7K1000 - 1TB
Display(s): 15.6" IPS Display (1920 x 1080)
Old - Given away
CPU: Intel Core i7 2630QM
RAM: 6GB
GPU: Nvidia GT 540M
Storage: Samsung 840 Pro - 128GB, Toshiba - 750GB
Display(s): 15.6" Display (1366 x 768)
Operating System: Windows 7
Other (Audio & Devices)
Speakers: Creative Gigaworks T40 Series II
Headphones: Sennheiser Momentum - Over-Ear
Bluetooth Speaker: Logitech UE Boom, Logitech UE Boom 2
Tablet: iPad 4th Gen
Phone: LG G4
Phone Accessories:
3 Spare Batteries
1 Battery Pack (10000 mAh)
IEMs: Can't Remember....
Retired Devices:
Samsung S4 (Broke... Half Fixed, Given away)
NDS (Traded in)
iPod Touch 2nd Gen (Traded in)
iPod Touch 4th Gen (Damaged Power Connector)
https://linustechtips.com/topic/421813-checking-power-supply/
you should be fine if you don't go too far. If you want to push it a bit more, get at least a 1000w power supply.
You are fine. 750W is plenty for that setup.
Generally 750w is the sweet spot for 2-way SLI. But, if you're overclocking, it might be a slight problem. You should be good though, just don't max everything out.
Ok cool thanks for that reassurance.
So I should be fine if I don't over-volt? So if I wanted to experiment further (with over-volting) I should look at getting a new PSU?
Desktop Build
Laptop
Current
RAM: 16GB
Old - Given away
RAM: 6GB
GPU: Nvidia GT 540M
Phone: LG G4
Phone Accessories:
3 Spare Batteries
Retired Devices:
NDS (Traded in)
https://linustechtips.com/topic/421813-checking-power-supply/#findComment-5665136
Feel free to experiment as much as you want. 750W is more than you need. You may be hiting it ONLY if you run the most demanding benchmarks for GPU and CPU at the SAME time. No way you will be hiting your PSU limits while gaming.
You are going to use around 550W-650W while gaming at most with a lot of OC done.
https://linustechtips.com/topic/421813-checking-power-supply/#findComment-5665144
Yes, I would recommend not only a higher wattage power supply, but also a high-efficiency one. Anything including and above 80+ Gold is rock solid. Stick with brands you trust, like SuperFlower, SeaSonic, and Corsair.
only if you really want to push your PC.
Ok cheers, I shall just tip toe into the region of over-volting, and if need be wait till I get a better PSU.
what you could try is getting a little device that measures how many watts the PSU is pulling out of the wall so you can see if it's near the limit
I will look into getting such a device, it would be helpful and it's not like it will lose it's use over time.
Desktop Build
Laptop
Current
RAM: 16GB
Old - Given away
RAM: 6GB
GPU: Nvidia GT 540M
Phone: LG G4
Phone Accessories:
3 Spare Batteries
Retired Devices:
NDS (Traded in)
https://linustechtips.com/topic/421813-checking-power-supply/#findComment-5665423
