I recently upgraded too windows 10 free upgrade and ever since my speakers are buzzing when playing videos and lagging need help please
Welcome to the Forum.
Please give us your full specs. I assume you haven't reinstalled your drivers. If this is the case, please download the latest drivers from your manufacturer/s. If there aren't any Windows 10 drivers out yet, I suggest you try the Windows 8.1 ones.
Sig under construction.
https://linustechtips.com/topic/421548-help/#findComment-5661910
dell xps 15
windows 10 32bit but has 64 bit architechture
12gb ram
intel core i5
cpu 2.5ghz
nvidia geforce gt 540
This might be a driver problem. I suggest you go to your laptop site and download all the drivers for you specific laptop. After downloading all of them uninstall the current drivers, restart your laptop, install the downloaded drivers and restart your laptop again.
May I ask why you use a 32 bit Windows?
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/421548-help/#findComment-5662051
would it be the audio driver ?
It can be, but you should install the 64 bit version before doing anything else, since the 32 bit version can only use 3 gb of memory and some programs require a 64 but Windows.
https://linustechtips.com/topic/421548-help/#findComment-5662316
how do i get it off windows tho
I don't know what you mean by that. Could you also press quote on my posts when you answer instead of making a new post? I get notifications that way :)
https://linustechtips.com/topic/421548-help/#findComment-5663832
