Hey guys new to this fourm but im an avid watcher of linus' youtube, i have a dell inspiron i3847-2773 i have added 8gb of ram, a evga 750ti the big gpu and also a cx670m power supply i want to upgrade the motherboard but i dont know what will fit into it, i want the best for gaming and under about 500 i have found a coupple that i will link down below, along with a few other things i want to put into the computer, any help will be apriciated, TIA
Motherboard - http://www.staples.com/Asus-GRYPHON-Z97-32GB-Micro-ATX-Desktop-Motherboard/product_1179155
liquid cooling Cpu - http://www.staples.com/Antec-KUHLER-H2O-650-Maximum-Performance-Single-Fan-Liquid-CPU-Cooling-System/product_IM1UW5361
SSD - http://www.staples.com/Kingston-V300-Solid-State-Drive-2-1-2-inch-SATA-600-Internal/product_IM1QM6571
CPU - http://www.staples.com/Intel-Core-i5-Quad-Core-i5-4670K-34-GHz-Desktop-Processor-Socket/product_IM1QX8541
thank you guys for any input
https://linustechtips.com/topic/421367-please-help/
Fistly dont shop at staples the prices for those things are way too expensive. Secondly wait for skylake and see how things turn out. Thirdly dont go for that SSD it is slow
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/421367-please-help/#findComment-5659723
Motherboard - Good choice
Cooler - WTF IS THAT LOL
SSD - I highly recommend staying away from the V300 SSDNOW series, get an MX200 or 850 EVO
CPU - Get 4690k if you can
https://linustechtips.com/topic/421367-please-help/#findComment-5659729
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($72.89 @ OutletPC)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive  ($134.78 @ OutletPC)
Total: $410.60
Generated by PCPartPicker 2015-08-02 04:54 EDT-0400
How about this? it should preform much better
Also get a GPU upgrade ASAP use the extra 90 dollars to go twords a 380 or a 280x and a ATX board should fit in the case, as most mid towers will
https://linustechtips.com/topic/421367-please-help/#findComment-5659750
yeah i just found those on staples just searching through stuff to upgrade, do you guys know if those would fit into the case? or would i have to buy a new case, im new to this pc gaming, im just over console bull shit
you shouldn't need a new case and for the love of god never use staples again, it should fit into the case, if you want to be safe, and if you use my build you can take out 20-50 dollars for a cheap case of your choice
https://linustechtips.com/topic/421367-please-help/#findComment-5659817
