CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor (£169.28 @ Amazon UK)
Motherboard: MSI H81I Mini ITX LGA1150 Motherboard (£50.99 @ Amazon UK)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory (£49.07 @ Aria PC)
Storage:
Crucial BX100 250GB 2.5" Solid State Drive (£65.15 @ Amazon UK)
Storage:
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£32.40 @ Aria PC)
Video Card:
Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card (£265.99 @ Aria PC)
Case: Silverstone ML07B HTPC Case (£51.00 @ Scan.co.uk)
Power Supply: Silverstone 500W 80+ Gold Certified Fully-Modular SFX Power Supply (£67.80 @ Scan.co.uk)
Total: £339.07
So I posted this towards the beginning of the year and there were no complaints. I'm actually at the time where I'll start buying stuff now so just want to make sure nothing's changed in terms of best value for money in regards to the cpu, case and mobo. I know Skylake's on the horizon. Ideally I'd like to purchase and build this month but if there's really something of better value to be released in Sept I guess I could wait.
And to clarify - parts in red are being taken from my current build.
EDIT:
Big part of its use at uni will include programming (and emulation) and minor gaming.
I won't be making any changes for ~3 years.
Will be carried/based in London.
Edited by jayctech
https://linustechtips.com/topic/420840-small-build-for-uni/
You might want to go for a i5-4690K <- you can overclock even you want to.
Then he also need a Z97 board
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/420840-small-build-for-uni/#findComment-5653499
I second this. The 4690 is a waste of money. Either go for the 4460 or the 4690K.
If not, go with a cheaper i5-4460
Thanks. I've added a couple of points. Do your opinions still stand even with those factors?
https://linustechtips.com/topic/420840-small-build-for-uni/#findComment-5653542
Storage: Crucial BX100 250GB 2.5" Solid State Drive (£65.15 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£32.40 @ Aria PC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card (£265.99 @ Aria PC)
Total: £339.07
either you get a 4590 cpu or you go full boar and get the 4690k with a z97 board and overclock the sucker to 4.6 ghz on the core. your pick. i noticed that you are unable to get a 390 because of the lack of 650w psu's. i added the node instead. added a better ssd.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  (£154.92 @ Aria PC)
Motherboard: MSI H97I AC Mini ITX LGA1150 Motherboard  (£78.85 @ Amazon UK)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-2133 Memory  (£44.39 @ Scan.co.uk)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£72.97 @ Amazon UK)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  (£262.99 @ Aria PC)
Case: Fractal Design Node 304 Mini ITX Tower Case  (£59.58 @ Amazon UK)
Power Supply: SeaSonic 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£110.70 @ Scan.co.uk)
Total: £816.80
Generated by PCPartPicker 2015-08-01 17:25 BST+0100
BigDay
https://linustechtips.com/topic/420840-small-build-for-uni/#findComment-5653602
Total: £816.80
Thanks for the suggestion but as stated, the parts in red are being ripped from my current build to save money. :) That includes the gpu, storage and memory. That and the Fractal's design is just a pain for transporting around London.
https://linustechtips.com/topic/420840-small-build-for-uni/#findComment-5653682
A (more expensive) alternative to the 4690 is the Xeon 1231 v3 which has hyperthreading. It's basically an i7 without the integrated graphics unit. Otherwise you should, like the others said take a lower i5 wfor less money.
who cares...
https://linustechtips.com/topic/420840-small-build-for-uni/#findComment-5653712
z97 overclocks better but i dont think its required
H81 may support overclocking a G3258, but overclocking/overvolting a 4690K with an H81 board would most likely cause the VRMs to overheat and could cause major longevity issues for the CPU and board.
https://linustechtips.com/topic/420840-small-build-for-uni/#findComment-5654269
