Louder =/= better.
You need to be careful in the audio world, because a lot of it is affected by the placebo effect, and there's a bunch of snake oil.
What was this "difference" you heard?
The stars died for you to be here today.
A locked bathroom in the right place can make all the difference in the world.
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5656659
You can't enhance audio. Software like that uses effects and compression, all of which actually degrades the signal. It's fine if you like what it does, but if you're looking for hifi avoid it.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5657257
  • 2 weeks later...
Louder =/= better.
i can totally hear a difference when i turn it on and off, it's easy to turn on and off the software. now the difference that i hear is in clarity. this bad headset that i'm using sounds like an open headphone, as if the sound isn't coming from inside my head rather from the room. and etc etc.
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5757607
please try it, i want to hear your real opinion after you hear the difference. you can just pirate it a few second and uninstall it again, or just use the free version.
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5757613
It may add a different equalization, but that's all it can do.
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5760056
that intrigued me into another question, from what you say i can deduct that without this software we should be able to equalize our sound however we want, so how can i do that? because i really want to fine tune my sound.
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5762418
There should be an audio manager in windows control panel.
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5763126
it doesn't show anything i can equalize. very barebone.
You sure you have an audio manager that came with your audio drivers?, like Realtek's HD Audio Manager thingie.
https://linustechtips.com/topic/420628-dfx-audio-enhancer/#findComment-5770837
