My First Build!
Go to solution Solved by Untouchable,
Unfortunately, when I checked my sites stocks they only have Asus strix, sapphire and power colour cards, so which would you choose out of these?
Likely the Sapphire card.
Hello, I'm here to ask if these components will be happy to work with each other, I've selected them from my preferred Malaysian supplier so keep in mind I might not have your suggested components.
Here's the list:
CPU - i5 4690 (4 CORE/4 THREADS/3.9 GHZ)
MOBO - ASROCK Z97 Fatal!ty KILLER (ATX / M.2 / 4xDDR3 / 6x Sata3)
RAM - Avexir Core Red 2x4GB DDR3 1600mhz (CL9)
GPU - ASUS GTX 960 Strix 4GB DDR5 128Bit
PSU - Seasonic M12II-620 EVO (80+ Bronze/ Full Modular/ 5 Years Warranty)
Cooler - Coolermaster Hyper T4 (152.3MM) [Not sure about this one]
Chassis - Bitfenix Shadow Window
HDD - WD 1TB Caviar Blue
Monitor - BENQ 24" RL2455HM
Peripherals - CM Storm Octane (KB & Mouse)
OS - Windows 7 Pro 64 Bit OEM
ODD - ASUS External SDRW08D3SU
There it is, I have a limited budget of 4800 ~ 4900 (GBP 803 ~ 820) (USD 1255 ~ 1281)
Thanks for you time guys!
oh shit waddup heres some specs
CPU i5 6600K MOBO ASUS Z170 Sabertooth Mark 1 RAM GSkill RipjawsV GPU Nvidia GTX 1070 PSU Seasonic S12II-620
COOLER Corsair H100i V2 CASE NZXT H440 HDD WD 1TB Caviar Blue SSD Samsung 750 PRO 120GB
https://linustechtips.com/topic/420503-my-first-build/
In terms of parts, it looks good! In terms of price though, I'd like to see the price of each part so I'll have a better idea
CPU: i5-6600k @ 4.4GHz | Motherboard: Asus Z170 Pro Gaming | RAM: 8GB HyperX Fury | GPU: Asus Strix GTX 980 | Case: NZXT Noctis 450 Red/Black | Storage: 256GB Sandisk SSD + 1TB Western Digital HDD | PSU: EVGA 750w | Monitor: ASUS VS247H | CPU Cooler: Cooler Master Hyper 212 Evo | Keyboard: $15 Cheapo Rubber Dome Keyboard | Mouse: Rosewill RGM-300
Linus Tech Tips Pebble (and Pebble Time) notifier watchface!
https://linustechtips.com/topic/420503-my-first-build/#findComment-5649843
yes,that will work fine each other
for cooler i think it's fine,because you can't overclock the processor
psu watt is over but you have  headroom
because you are in malaysia,always check your local price,rather than newegg,amazon or other america or europe online sites
https://linustechtips.com/topic/420503-my-first-build/#findComment-5649853
http://idealtech.com.my/store/builder/show.php?serial=0NS9D342 Here is the site I'm getting parts from, sorry there aren't conversions
https://linustechtips.com/topic/420503-my-first-build/#findComment-5649888
I wouldn't buy a 4GB 960..
and why is that, be gentle I'm new :P
https://linustechtips.com/topic/420503-my-first-build/#findComment-5649897
R9 380 would be a much better option for the graphics card.
Do you suggest the reference or a certain company's version
https://linustechtips.com/topic/420503-my-first-build/#findComment-5649923
MSI makes a great one, Sapphire Nitro series is also good, but not great. XFX if you can't find the other 2, but i don't recommend them as a first choice.
https://linustechtips.com/topic/420503-my-first-build/#findComment-5649956
that's right 380 perform better,but need more power than 960
difference performance 1-5 fps,depends on what game and setting
Since you said I have headway, does that mean I can power this card?
https://linustechtips.com/topic/420503-my-first-build/#findComment-5649975
Would getting the turbo version be wise?
Edit: whoops I meant nitro
https://linustechtips.com/topic/420503-my-first-build/#findComment-5650003
Here's the list:
  • get a 4690k if you have a zboard so you can overclock it
  • get faster ram at like 2400 mhz if it's around the same price
  • get a 380 over the 960 with 4gb of vram
  • seasonic psu's are great
  • you will need a stronger cpu cooler for an overclocked i5. h60 or noctua nh-u14s
  • get windows 10
  • get a 1ms 144 hertz monitor
BigDay
https://linustechtips.com/topic/420503-my-first-build/#findComment-5650132
  • get windows 10
I wasn't planning on overclocking much at all
PC part picker said that a locked processor can't handle 2400mhz
I already planned for a sapphire r9 380 nitro with a few other members
I'm planning for windows 10, but my supplier doesn't sell it yet
And could you suggest a good monitor?
Thanks for all the advice man but sorry that I don't really want to overclock because these ideas are great!
https://linustechtips.com/topic/420503-my-first-build/#findComment-5650257
if you aren't overclocking, getting a z97 board is kind of a waste of money.
https://linustechtips.com/topic/420503-my-first-build/#findComment-5650506
What board would you recommend and at the same time is black and red
https://linustechtips.com/topic/420503-my-first-build/#findComment-5650529
you could go with a gigabyte h97-gaming 3, or asrock h97 performance. both these boards are black and red and seem to be cheaper than the z97 you listed
Thanks so much for the help!
https://linustechtips.com/topic/420503-my-first-build/#findComment-5650599
2400 mhz is the xmp profile of the ram. it's the overclocked frequency. that's how they advertise it. you may have to increase the dram voltage to make it work @ 2400 otherwise it'll just downclock to 1600 mhz
BigDay
https://linustechtips.com/topic/420503-my-first-build/#findComment-5651079
