Eyefinity setup help?
By
aphelps23
in Graphics Cards
in Graphics Cards
Solved by W-L,
Woh thanks for the quick reply! I'm about to order an R9 390. That works with an HDMI and two DVI and Eyefinity enabled, yes?
Yep that should work the new cards shouldn't require mandatory use of use display port or any adapters.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
