Hello LTT family i am making a build for my parents as the need a computer upgrade and were going to buy a pre built one and i told them no! lol
http://pcpartpicker.com/p/dBhcsY
would you change/edit any thing in this list? if so, why? let me know. :)
They have a budget of $800.
https://linustechtips.com/topic/419756-making-a-build-for-parents/
What's the system being used for?
Change the mobo to a non-Z type motherboard, will save you abou $30 and you don't really need it.
If you are going for a quiet PC, wich I assume you are since you are watercooling a non-K processor, you might want to consider some very quiet fans like the Noctua NF-F12. Though you might want to wait to see how loud the PC is going to be with these components.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
Your parents are gona really appreciate you wasting money for NO REASON on that AIO watercooler and an expensive Z mobo.
But most importantly - what is the system gona be used for?
Cuz if its for everything besides demanding gaming, its better to get this:
http://www.amazon.com/Zotac-ZBOXNANO-AQ02-U-Quad-Core-A8-5545M-Barebone/dp/B00K8QE6YC
Fit it with a 256 gig SSD and mount it to the back of this:
http://www.amazon.com/Philips-274E5QHAW-00-LED-Monitor-68-6cm/dp/B00CP0YWGQ/ref=sr_1_2?ie=UTF8&qid=1438336233&sr=8-2&keywords=PHILIPS+274E5QHAW
They`ll appreciate that way more - and actually enjoy using an SSD pc that doesnt have a PC tower, not to mention they`ll REALLY enjoy that 27" IPS 1080p monitor.
Thats what i`d make for my parents if it wasnt for any demanding gaming.
do they need a gpu? what are they using the pc for?
BigDay
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($189.99 @ NCIX US)
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($33.99 @ NCIX US)
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  ($65.98 @ Newegg)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1866 Memory  ($42.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($71.98 @ OutletPC)
Storage: Seagate  1TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($73.45 @ OutletPC)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($68.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.75 @ OutletPC)
Total: $656.11
Generated by PCPartPicker 2015-07-31 06:12 EDT-0400
BigDay
