Im looking for a program to uninstall a metric butt-ton of bloatware on my system. I just upgraded to windows 10 and well.. there is a ton of stuff that i want to get rid of to clean it up. I wanted to originally format and reinstall but i dont have an actual 10 Key as it was an upgrade from 8.1. So what I'm asking is there a RELIABLE/SAFE program to uninstall programs in mass??
thanks for the help!!
--Mvard
https://linustechtips.com/topic/419253-pc-cleanup-help/
--Mvard
xdo it manually i find it much more effective :)
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5634974
Well, you could use CCleaner to uninstall them all manually.
Though the easiest way is just reinstall windows lol.
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5634981
--Mvard
Reinstall OS, and just put the files you need like music/pictures/documents or anything onto a External Drive or USB. I find that this way, there's a performance gain :D
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5634985
search bar> disc management> format drive
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5634997
Ehhh, I reinstall the OS as a whole, why? Takes literally 5 minutes to install the OS from plugging the drive in to Setting up, hell most of my Music/Docs/Pictures are either backed up automatically or are already in the external drive. On both SSDs, there are only games and some jiggy jiggy stuff. Also depends on the hardware you have tho, if you have high end stuff, it would take a while for it to slow down.
Main Rig
 XENON Build:
Office Build:
Phone
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5635029
cus format ;(
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5635041
cus format ;(
Main Rig
 XENON Build:
Office Build:
Phone
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5635065
So basically format with a clean install of windows 8 then re-upgrade to 10? (this is an hp laptop btw i.e all of the bloatware)
HP Laptop with all the junk? If it really matters, reinstall Windows 8 as a whole then upgrade. Find a way to get another product key I guess, maybe from DreamSpark if you're enrolled in a University or buy it.
Main Rig
 XENON Build:
Office Build:
Phone
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5635078
Meh, okay... is there a way to do it without reinstalling 8 then upgrading to 10??
Formatting. Not really sure if formatting will keep all the HP crap tho. I had a Dell Craptop before  that actually had an i5 in it "surprisingly" and it actually didn't have preinstalled junk.
Main Rig
 XENON Build:
Office Build:
Phone
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5635100
You can install Belarc adviser to get your windows product key and then you can do a clean install.
CPU: Intel i5 4690k @4.3GHZ COOLER: Arctic Freezer Pro 7 Rev 2  MOBO: Asus Z97-E RAM: Kingston Hyper X Black 2x4GB GPU: Soon to be EVGA 1070! Case: Fractal Define S Storage:PNY 240GB SSD, 500GB Seagate Barracuda PSU: Corsair RM650x
https://linustechtips.com/topic/419253-pc-cleanup-help/#findComment-5635426
