Im wanting to do a slight upgrade on a tight budget. Im talking about a ramen noodle budget. My rig is quite a few years old now and wasn't top of the line back then really. I know that I need more RAM and an updated GPU. Any advise on one and other upgrades that I can make to beef it up just a bit. Im looking to play Witcher 3 (and perhaps Arkham Knight once they get it worked out) with playable FPS on low to mid settings. Curent rig:
Thermaltake Lanbox (space is an issue)
EVGA GT 640 GPU
4 gigs of DDR2 RAM
AMD Phenom 9850 quad core 2.5 GHz
ASUS M4A785-m MOBO
Corsair TX600 PSU
https://linustechtips.com/topic/419191-upgrade-help-and-advice/
EVGA GT 640 GPU
4 gigs of DDR2 RAM
ASUS M4A785-m MOBO
Corsair TX600 PSU
What is your Budget?
https://linustechtips.com/topic/419191-upgrade-help-and-advice/#findComment-5634280
