Please get an i3 just save for it as skylake is coming out soon
Right now I am looking at the AMD Athlon X4 860X as my CPU. It's use will be a medium amount of gaming like Civ V, TF2 and Fallout 4 when it comes out. Do you think the X4 is good enough or should I look for a better CPU.
Please get just save for a skylake i3 as it is coming out soon
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/418771-help-with-picking-a-cpu/#findComment-5629355
That's terrible advice. If you want someone to wait for skylake, then just wait for skylake, dont tell them to buy a brand new CPU for a month or two...
If anything if they needed a very cheap CPU for that length of time at least recommend the G3258
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/418771-help-with-picking-a-cpu/#findComment-5629368
Would you like to be stuck in a dead socket with no upgrade path?
No? Go i3 and an LGA 1150 motherboard
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/418771-help-with-picking-a-cpu/#findComment-5629371
I was saying save and by the time you have saved skylake will have released
https://linustechtips.com/topic/418771-help-with-picking-a-cpu/#findComment-5629375
Ok, just hard understanding what you wrote originally then I guess.
My Rigs:
Case:
Case:
https://linustechtips.com/topic/418771-help-with-picking-a-cpu/#findComment-5629384
Moving from an AMD CPU to a Intel CPU was a waste of money for me. The only perk I see (which is the only thing i did it for) was I could upgrade using one socket and mobo. So if you want to upgrade eventually.. go for Intel, but if you don't plan on upgrading, the AMD will work just fine. Both are great. GOOD LUCK! :)
CPU: I7 8086K                              MOBO: Gigabyte Z370 Aorus Gaming 5   RAM: 16Gb G-Skill 3200mHz
GPU: GTX 1070 FE 8GB            CASE: Phanteks Enthoo Evolv ATX           OS: Windows 10
PSU: EVGA 650G                      SSD: 250GB Samsung Evo                       HDD: 1000GB WD BLUE
https://linustechtips.com/topic/418771-help-with-picking-a-cpu/#findComment-5629389
