Virtual super resolution problem
Go to solution Solved by VortexS,
I have a r9 290 and when i use vsr the max resolution i can use is 3200x1800 instead of 3840x2160.
thanks
4K VSR is only supporters by the new achritecture, I believe the R9 285 supports it.
thanks
Penguins or something random
(Main) Liquid Shadow V3 CPU: 5960x@ 4.7, Mobo: EVGA X99 Classified,RAM:G.Skill 16Gb 2666 ,GPU: 2 GTX 980Ti ClassifiedsPSUEvga Supernova 1000G1,Storage: Sandisk Ultra 2 480gb, WD Blue 1tb x3Case: Cooler Master Cosmos 2 25th Anniversary Edition
Liquid Shadow V1 CPU4790k@ 4.7, Mobo: MSI Z87X-Power,RAM:G.Skill Sniper 16Gb OC@1866 ,GPU:  2 Sapphire 290x's watercooled, PSUEvga Supernova 1000G1,Storage: Sandisk Ultra 2 480gb, WD Blue 1tbCase: Cooler Master HAF X
Extra Rig: Cpu: 4790k@4.7, Mobo: MSI Z87X-Power, Ram: 32Gb Corsair Vengeance/G.Skill Sniper,  GPU: 3 GTX Titans, Psu: Evga Supernova 1300G2, Storage: Case: Cooler Master HAF X
(First Rig)The Enforcer: CPU: FX 8350@ 4.6,Mobo: Gigabyte 990fxa-ud3,RAM: HyperX 8gb @2133,GPU: Diamond Multi Media r9 290,PSU: XFX XTR 750, Storage: Adata Premier SP550 480gb, Case: HAF 912
Peripherals Razer Naga Epic Original, Razer Deathadder,Logitech G910 Orion Spectrum, Logitech G13, HyperX Cloud
https://linustechtips.com/topic/418316-virtual-super-resolution-problem/
thanks
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
This should be helpful
LTT Unigine SUPERPOSITION scoreboardhttps://docs.google.com/spreadsheets/d/1jvq_--P35FbqY8Iv_jn3YZ_7iP1I_hR0_vk7DjKsZgI/edit#gid=0
Intel i7 8700k || ASUS Z370-I ITX || AMD Radeon VII || 16GB 4266mhz DDR4 || Silverstone 800W SFX-L || 512GB 950 PRO M.2 + 3.5TB of storage SSD's
SCHIIT Lyr 3 Multibit || HiFiMAN HE-1000 V2 || MrSpeakers Ether C
