PCI-e Network cards speed question
Go to solution Solved by Crion,
You'll be fine.  PCI-E 3.0 x1 comes out to 8Gbps if I remember correctly.  PCI-E 2.0 x1 is 5 Gbps I think...
10 Gbps dual nic configured in LACP still nets you at a max of 10 Gbps for a single stream.
I'm on the look out for a new network card to replace my base 10 card (yes not 10/100 just plain 10 on the only PCI slot in my newish PC as a second card FYI) and have noticed that there are gigabit cards on PCI-E for around the $10 mark are they any good or completely bottle-necked on PCI-E or do you only get that speed on PCI-E x16 or motherboards?
and for another question There are 10 gigabit dual nic PCI-e cards do they get 20 gigabit throughput or not really? and how fast is the maximum theoretical speed of a PCI-e network card (for reference)
https://linustechtips.com/topic/418220-pci-e-network-cards-speed-question/
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
