I need a laptop for lightroom and photoshop and premiere pro and blender!
Musts -
1. Ips screen for image editing
2. 8 gigs of ram
I would like a discrete gpu if possible.
Budget - 800 cad
Please help guys!
@ShadowCaptain I made this thread coz the old one died (no one helped!) :'(
https://linustechtips.com/topic/418177-laptop-for-work/
Honestly for that budget I have no idea, I dont know any laptop with those specs for that price, certainly not with a dedicated GPU
More like 1300
https://linustechtips.com/topic/418177-laptop-for-work/#findComment-5622503
http://www.newegg.ca/Product/Product.aspx?Item=N82E16834232235
Unfortunately, this is the closest you can get for something brand new. IPS panels are only found in machines that are in the more expensive range.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/418177-laptop-for-work/#findComment-5622557
Uhhh well which is the cheapest laptop with a good ips screen?
https://linustechtips.com/topic/418177-laptop-for-work/#findComment-5622602
https://linustechtips.com/topic/418177-laptop-for-work/#findComment-5622790
