So for those who are getting a failed W10 update code 80240020, I found a fix on reddit: https://www.reddit.com/r/windows/comments/3eyrre/fix_for_the_80240020_error_when_trying_to_install/
Basically, go into C drive, Windows, Software Distribution, and Download. Delete everything in that folder.
Then go to cmd, type wuauclt.exe /updatenow, and then W10 should start downloading within the updates section from scratch.
This worked for me at least, hope it helps others!
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/418118-fix-for-w10-code80240020/
only if it wasnt posted 255 times before.
https://linustechtips.com/topic/418118-fix-for-w10-code80240020/#findComment-5621840
ty for such a great post
https://linustechtips.com/topic/418118-fix-for-w10-code80240020/#findComment-5621865
