I am building a PC and here are the products i am trying to buy..
1. ASUS H81m-CS motherboard
2. Corsair Vengeance ddr3 ram 8gb or 4gb x2
Or Gskill Ripjaws X ddr3 ram 8gb or 4gb x 2
Both 1600mhz
3.Intel core i5 4440
4.450 watt power supply
5.Cabinet is nothing special just plain cabinet at the most i might buy cooler master elite 311
5.I have my old grafix card AMD Radeon hd 6670 ddr5 1gb
My main concern is the compatibility issue like:- The Form Factor, Ram Dual and Quad channel,micro atx, I am a fan of Asus products so..do you guys prefer gigabyte,msi,wtc...Please help.. will it all be compatible...etc.etc.
Or recomendation and suggestion of changing the parts etc.
I think my ram will be 8gb max...
THERE IS NOT MUCH TO CHOOSE FROM MY LOCALITY SO... i will be ordering from Snapdeal (Indian online store..if u can give me suggestions from this site, would be awesome)
I will be using it for normal uses...playing a bit of games like fifa,gta5,assins creed,etc.
https://linustechtips.com/topic/417989-need-help-in-building-pc/
Is there any difference between x2 4gb single module ram (meaning x1 4gb ram is packed in one box) and x2 dual channel ram (x2 4gb ram both packed in one box).. because there IS NO x2 4gb corsair (2 4gb rams packed in one box) ...only 1 ram in 1 box
https://linustechtips.com/topic/417989-need-help-in-building-pc/#findComment-5621453
The 2x4 was tested by the maker, and is a higher chance of working in dual channel mode.
https://linustechtips.com/topic/417989-need-help-in-building-pc/#findComment-5621794
dude
what is your budget?
The thing that i Post is about it...because i am ordering from Snapdeal(online shop) and there is not that much to choose from..it is very limited...if u can go to the website, would be very awesome i need to complete it for like Rs.27,000 (INR)
https://linustechtips.com/topic/417989-need-help-in-building-pc/#findComment-5628411
