Dollars. Australian? Canadian? U.S.?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5617828
I need a good pc build ranging from 700-750 dollars with a keyboard. (I dont need OS).
Location? also do you need a monitor?
PC is alive again! :System: CPU:Intel i5 4960k/ Motherboard:ASUS Gryphon Z97/ RAM: Kingston 16GB/ GPU: ASUS R9 Fury X/ Storage: 120gb Crucial SSD, 2TB Seagate SSHD/ PSU: Cooler Master 700w/ Displays: 1 Acer B276HK ymjdprz 27-inch 4K Ultra HD/1 ASUS 21.5 LCD LED 21.5 monitor
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5617908
It's a little over budget, but I believe this is a pretty alright build for a first gaming pc
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard  ($67.98 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($50.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($299.99 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($56.99 @ NCIX US)
Keyboard: Logitech G15 Wired Standard Keyboard  ($27.99 @ PCM)
Total: $777.37
Generated by PCPartPicker 2015-07-29 01:10 EDT-0400
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5618312
Total: $777.37
Hi, sorry noob here. just a quick Q. when dya need a cpu cooler? i noticed you didn't include any
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5619104
For a non-overclocking cpu and motherboard, the stock cooler should be enough.
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5619414
Total: $777.37
This build looks really fine. But i am not s sure about the Mini ATX. Sure its Badass but for later upgrades and stuff normal ATX is still better.
So do you want a small pc or better upgrade compability later/use some adin PCi stuff like a wifi card etc?
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5620047
I mainly went with a micro atx since it's typically more price friendly for budget builds. I'm sure there's other fair priced atx builds, but this one also allows more investing in other parts
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5620094
Yes thats true. But ya basically he has to decide. There are also nice and cheap ATX parts out there. So its your decision what you wanna buy.
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5620113
chose a z97 so that you can upgrade your cpu and overclock in the future
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($189.99 @ NCIX US)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($94.99 @ NCIX US)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1866 Memory  ($42.99 @ SuperBiiz)
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  ($229.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($76.99 @ NCIX US)
Keyboard: Logitech Corded Keyboard K280e Wired Standard Keyboard  ($9.99 @ NCIX US)
Total: $757.42
Generated by PCPartPicker 2015-07-29 11:27 EDT-0400
BigDay
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5622776
I like the build. I do play some minecraft and the amd cards have a problem in it. Is there any way to fix the problem because i do like the 380 a lot
make sure you quote one of us so we know you replied
what problems do they have in minecraft? i've never heard of that before
if you don't want the 380, get the 960. it's a slight step down in performance though
BigDay
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5622920
Theres a chunk rendering problem. When even a powerful card tries to run the game, instead of getting the fps it should be, there is a massive drop to arround 40 fps when the card is able to get around 400
https://linustechtips.com/topic/417748-first-gaming-pc-build/#findComment-5622977
