Can't install Intel Management Engine Interface update
When I try to install the update I get this error, any suggestions?
(Sorry if the images are too big)
Main Board: ASUS MAXIMUS VII HERO | GPU: MSI GTX 980 4G GAMING | PSU: EVGA SuperNOVA 850 G2 | CPU: i5 4690k | Memory: CORSAIR VENGANCE PRO 2x8GB 1866Mhz | SSD: 250GB SSD Samsung 840 EVO | Operating System: Win 7 Pro 64bit
Because it often causes issues and makes things worse, Windows Update should only be used for Windows stuff.
Get drivers and all that stuff directly from Nvidia/AMD and your Motherboard manufacturer's website
I guess I have the latest drivers installed? And windows update is showing a 3mb update, the whole driver is 80mb.
If Asus has nothing new for your motherboard I'd think so.
I've had the exact same Management Engine Interface update there forever, I've just ignored it.
On Windows 8.1 at least it's under "Windows 8.1 and later drivers", I don't update anything Windows Update says to be a driver.
Go to your mobo manufacturer and download the driver from there.
Happy to help with any tech problems. Windows 10 installing guide here.
----i5 4570s----gigabyte z97x-sli----8gb ddr3----gigabyte g1 gaming 960----HAF 912----120gb ssd----1tb hdd----500w evga----
Agreed, only use windows updater for windows updates.
