Not Compatable?
Solved by 79wjd,
The cooler is too tall for the case. You need to get a case which has 160mm of clearance.
Also, go with a locked i5 and an H81 board unless you plan on upgrading the G3258 immediately. Go for a different ssd (the V300 is terrible), try and step up to an R9 280/x (even if it means getting a cheaper PSU), and lose the fans.
PopsicleHustler ·
Posted in Audio2 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory11 -
11
play_circle_filled
Latest From ShortCircuit:
