Any good brand will do.. the time where nice thermal paste was important is already on the past
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/417336-best-thermal-paste/#findComment-5612350
The only important thing about them is that they are not conductive. But I think every paste today inst conductive any more.
I personally like the MX4 most, because its not super expensive and simple to apply. But in general everything will work fine. Much more important is how you apply em. and don't use to much
https://linustechtips.com/topic/417336-best-thermal-paste/#findComment-5612406
1. Coolabratory Liquid Ultra
2. Gelid GC Extreme
3. Noctua NT-H1 / MX-4
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/417336-best-thermal-paste/#findComment-5612450
Did you watch the Video about it?
Linus tells its BS and i tried it and basically it was BS
did you really get better temps?
I've never used it before, but I remember seeing a thermal paste round up and the Coolabratory came on top. Linus even said they might have applied it wrong.
https://linustechtips.com/topic/417336-best-thermal-paste/#findComment-5612633
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-17.html
http://forum.techinferno.com/alienware/7460-tested-all-thermal-paste-range-best-them.html
https://linustechtips.com/topic/417336-best-thermal-paste/#findComment-5612654
