I am buying a new case tomorrow, most likely the R5. Do any users who have the Windowed R5 know if it scratches easily (like an NZXT S340 or my current case)? I am also torn on how to mount my radiator. I have a 240mm radiator. I think that I should mount it in the front (remove drive cages) and put it to push. I am worried about my already hot Titan X (though I am putting an ACX 2.0 on it). If I mount it on top, I am making a big compromise on the acoustics (need to remove moduvents). Thanks - Covert
https://linustechtips.com/topic/416909-define-r5-windowair-flow/
better to mount rad in front. otherwise the heat of the gpu gets in the RAD on top.
I would buy the regular R5 and buy Plexiglass sheet at homedepot for $15, like I did.. you can decide the size of the window you want. Mod the panel, if u can. otherwise buy windored version.
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5606957
Put the rad on push/pull on the front. That way you'll get great airflow for your GPU. I know it doesn't make much difference in CPU temps but it can provide wicked airflow without removing the top modu vents. I would put a focused airflow fan on pull so you get more direct air to your GPU and mobo. AP123, AP121, NF-F12, NF-P12, even spectre pros, you will run them slowly anyway since it's push/pull, it's just taking advantage of the arquitecture of those fans.
If i sounded a bit bossy, this is just a sugestion.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5607095
I'm afraid that it will be warm airflow.
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5607974
Not at all, same principle as why the order of a water cooling loop doesnt matter, fluids don't heat up significantly by passing by warm objects, maybe a degree. The reason i'm recomending it is because i changed to that config and the temps of my GPU went down 5 degrees compared to pull, so did the mobo VRMs, so it worked great for me.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5608037
That's strange, the fans are meant to exhaust the heat from the rad, theoretically heating up the GPU.
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5608067
Damn. Off to Home Depot like @Dabasepc suggested.
I may have mislead. It was the review of the Define S and the R5 video was the windowless version. I'd imagine it would be the same material though.
There's the video of the review. Skip to 2:15 for the test.
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5608843
Well, in practice the difference is miniscule, and if you do push/pull is actually better than 2 intake fans.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5611910
see lol http://www.homedepot.com/p/OPTIX-18-in-x-24-in-x-220-in-Acrylic-Sheet-MC-21/202038050 this is 18 inches x 24 inches.
My local store has thse for like $15 and it worked pretty good. My entire side pannel is a window, i ditched the rigid side panel lol. if i want silent pc, i just put back the rigid panel with sound damping material. thats it.
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5612230
10,27 here http://www.homedepot.com/p/OPTIX-18-in-x-24-in-x-0-093-in-Clear-Acrylic-Sheet-Glass-Replacement-MC-05/202038047?MERCH=REC-_-PIPHorizontal1_rr-_-202038050-_-202038047-_-N
https://linustechtips.com/topic/416909-define-r5-windowair-flow/#findComment-5612234
