salutations my fellow open source brethren, im running ubuntu and am attempting to make a kali live usb, the reasons for such aren’t important. i downloaded the iso and with the command terminal, did the following
-went to directory of the iso (in this case my downloads folder)
-and ran
sudo dd if=kali-linux-1.1.0a-amd64.iso of=/media/e bs=512k
-i received
dd: failed to open ‘/media/e’: Is a directory
i have zero idea what im doing so any help is greatly appreciated
https://linustechtips.com/topic/416880-linux-live-usb-dd-comand-need-help/
The 'of' variable has to be the device itself not the folder it's mounted in, i.e. /dev/sdx
where x is the appropriate drive letter e.g. sdb.
Be sure you get this right since this command deletes everything on /dev/sdx.
Also the usb drive must not be mounted. If it automounts you have to unmont it first.
