Mid tower water cooling
Go to solution Solved by ProGearUk,
wow didn't even realise both the 650D and 600T were Mid-tower x_x
The 650D is my favourite mid tower behind the Fractal Design Define R4 which is such an awesome case. No branding in it at all. Such a great case. Also I have heard and I think this is true, the 650D can max have a 50 mm rad in the top so some companies have 47mm rads which will give room for a set of 25 mm fans and the 47 mm radiator itself.
What mid tower cases can handle two 240mm rads? O.o I am struggling to find any.
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
https://linustechtips.com/topic/41604-mid-tower-water-cooling/
I think the 650D from Corsair is able to do it. Other than that there is things like the 600T from Corsair as well as a few from other manufacturers but I am not sure.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540122
Why do you want a mid tower for that kind of cooling?
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540128
Firstly, for spacial reasons (I don't think a full tower case would fit in my designated computer space) and secondly just because I like the look of a smaller case.
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540140
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540143
Corsair C70 can
There are some fractal cases that can
Feel free to message me if you want to chat!
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540146
The 600T and 650D can fit a 240 and one 200mm rad. you can mod the front to hold a 240
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540165
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540166
Well the switch 810 is good,  but is a full tower. The fractal arc midi r2 is really good. the micro version of the arc midi R2 holds a 360 and a 240 if i remember right.
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-540172
Sorry dbl post
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-546914
Well there is the Nanoxia deep silence cases as well which are like the fractal cases but I love the idea of separate doors not one big one and it also has 2 fan controllers that each control 3 fans each
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-546916
Same problem.  :P
Here are some cases http://www.overclock.net/t/1144409/h80-h80i-h90-h100-h100i-h110-case-compatibility-thread-page-1-for-full-listings
I prefer NZXT Phantom 410 Black. (
https://linustechtips.com/topic/41604-mid-tower-water-cooling/#findComment-547290
