Cooling?
Go to solution Solved by don_svetlio,
Sorry about this but do i5 and i7 need aftermarket coolers?
The i5 4460 doesn't need one but the 4590, 4690 and etc benefit a decent bit.
i7s actually overheat on the stock cooler *cough* 4790 *cough* so they aren't worth in this case.
the i3 is honestly more than fine for your needs.
CPU: Intel Core i3-4160 Haswell Dual-Core
Motherboard: GIGABYTE GA-H97-D3H LGA 1150
Video card: MSI R9 380 GAMING 4G Radeon R9 380
RAM: HyperX Fury Black Series 8GB 240-Pin
Storage:  Western Digital Blue WD10EZEX 1TB 7200 RPM
Case: Rosewill CHALLENGER - Black Gaming ATX Mid Tower Computer Case
Power Supply: Cooler Master Elite V2 - 550W
Optical Drive: Asus DVD-RW Bulk Drive
This will hopefully be my build in a few weeks (saving up my money)
So this is my set up and i was wondering if i should get a different fan for the CPU or just get another fan for cooling, also since i'm just starting PC gaming Building any tips would be much apreciated
https://linustechtips.com/topic/415906-cooling/
Waht games are you going to play?
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/415906-cooling/#findComment-5593992
i3s don't need aftermarket coolers for the most part. You will be perfectly fine even if pushing it to the max.
https://linustechtips.com/topic/415906-cooling/#findComment-5594010
Ok, I'd say, save up for an i5. Modern games like quad core CPUs.
https://linustechtips.com/topic/415906-cooling/#findComment-5594011
Just use the stock cooler.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/415906-cooling/#findComment-5594062
No, they don't need it. It's just better to have one as the CPU will stay cooler which may extend the CPU's lifetime. You will only need an aftermarket CPU cooler if you want to overclock.
I have an i5 4590 at stock speeds with a Cooler Master Hyper 212EVO on it. Max temp was 50 degrees C, while under 100% load.
https://linustechtips.com/topic/415906-cooling/#findComment-5594072
https://linustechtips.com/topic/415906-cooling/#findComment-5594074
depends on the model of the i5 or i7, if its a K version which means it can overclock than yes, you can benefit from an aftermarket cooler but for non k cpus like your i3 its not really gonna give you better performance except for lower temps and less noise.
https://linustechtips.com/topic/415906-cooling/#findComment-5594092
