Audio
Go to solution Solved by Sharif,
Oh, so even plugging in speakers to the motherboard would work? And thanks for the response sorry trying to figure out everything before I buy the parts... First build.....
It's fine,yup any 3.5mm audio male jack will work including home theater setups through S/PDIF Toslink ,In due time you will figure everything out,
If you have any other questions feel free to make a topic,somebody will surely help.
Good luck and good night
Have you tried connecting directly on front port/back port
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/415553-audio/#findComment-5589976
I know this makes it harder for u to answer.... But no I haven't because I am just figuring out all the problems before I buy the parrts
Oh in that case you shouldn't be worried all motherboards come audio jacks (even 5.1 or 7.1 setups,even the digital one) and your case also has a audio jack connected from your motherbourd.
ExSystems
https://linustechtips.com/topic/415553-audio/#findComment-5590009
https://linustechtips.com/topic/415553-audio/#findComment-5590041
ExSystems
https://linustechtips.com/topic/415553-audio/#findComment-5590073
Thanks!!
https://linustechtips.com/topic/415553-audio/#findComment-5590100
