Optimal sample rate and bit depth setting.
Just wondering what people usually have these set to, I usually just go highest bit and 44.1kHz as I heard upsampling the rate would introduce aliasing. Tried to listen to the differences, but all I can tell is upsampling makes the music slightly louder.
Talking about these btw.
https://linustechtips.com/topic/415445-optimal-sample-rate-and-bit-depth-setting/
There is no point is changing anything there.The only real difference you will hear is with a better sound card
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
I have a Fostex Hp-a8, and I've heard it does make a slight difference xD
I think that is a dac if i am righ.Even more when you have a dac.The point of one of those is to convert analog audio coming from your pc into a better sound
  • 4 weeks later...
Going beyond 44.1/16 is pointless.
A higher sample rate isn't going to sound better, and increasing the bit depth just decreases the noise floor, thing that you can only notice on a very, very quiet room.
The stars died for you to be here today.
A locked bathroom in the right place can make all the difference in the world.
