Hello everyone,
this is my first post on the forum so welcome to you all :D
i decided to go for a full watercooling loop for my setup and since i never done this before i need your help advice for all part of this project from the case mod to the water cooling parts, Here is my setup:
NZXT H440 White (Stock fans)
Asus Maximus VII Formula (Watercooling too)
intel Core i7 4790K
GTX 980Ti MSI (non custom)
Seasonic 660W Platinum
4x4 ram Corsair Dominator 2133mhz
SSD 850 PRO 256Go X 2
(NO HDD) here i saw serval mods that takes out the hdd rack so i will do that i think since i dont use HDD and not gonna use them !
What i already own:
Pompe : EK-DCP 4.0
Embout : 6 right, 6 of 45° & one 90°
Réservoir : Phobya Balancer 150 black
Sonde : Bitspower
Last questions:
- How much Rad do i need to watercool the Motheboard cpu and GPU ?
- I read in serval forums that the H440 case have a bad airflow so if some one can help me with this its will be great.
- do i need to change the stocks fan ? i prefear silence over performence but if there is one that do both am lestening :D
Thanks for reading me sorry for my english.
P.S : here is some pictures of my actual build
post-247427-0-38209000-1437855464_thumb.
post-247427-0-13407100-1437855507_thumb.
post-247427-0-23865400-1437855545_thumb.
https://linustechtips.com/topic/415374-first-watercooling-loop-need-help-please/
Well, H440 has easy support for 360 as far as I know, so that's probably what I'd use.
Don't really need more for a single GPU and CPU (the motherboard doesn't put out that
much heat). Hell, you could even get by with a 240 if you wanted to. But since you
have the space, might as well go 360, bit more headroom for turning down the fans.
Not really sure about that one as I don't know the case too well. I wouldn't worry
about this unless you get horrible temps after having put your system together.
If that turns out to be so, you can either mod the case or get a new one, but it's
not like there's some magic which will make your case have better airflow just like
that.
You mean the case's stock fans? Whether you need to is relative. Again,
I recommend putting your system together and then seeing if it performs as you
wish. If not, start thinking about making improvements then. Otherwise you'll
just end up spending money on things you don't really need.
Of course, if you want to change the fans, well then, nobody's stopping
you. :D
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
Hello everyone,
intel Core i7 4790K
What i already own:
Pompe : EK-DCP 4.0
Sonde : Bitspower
Last questions:
Get a 360mm rad, preferably a thicker one (45-60mm) and i would mount it on the front since your mobo is pretty bulky and may interfere on the top. You will wanna change the stock fans if you mean using them as rad fans, they are not made for that, i think EK ships vardar fans with their kits, if not, any decent high SP fan should do. Finally, you are watercooling your CPU, GPU and motherboard, don't worry about airflow, you only need some residual air for the rest of the mobo but really not something i would worry about. You can add another rad if you want, that's the point of watercooling, you can custom almost everything according to what you want, if it was me i would add a 140mm rad on the rear simple bacause i like how they look  but it's your build and your money, in the end it's up to you....just...have fun! What's the point otherwise :P
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
hey guys thanks for the answers :D
Are you sure one 360 Rad will be enough ? if so can you guys help me to get all parts that i still need ?
Thanks for the help :D
Yeah, it'll be plenty. We're just at the moment having a bit of a chat about rad space
over at OCN, and one guy is running two GPUs and a CPU off a 360 with his fans at 1100 rpm,
while another is running a 780 and a CPU off of a 240 without issues.
As for which radiator and other parts you still need: If I've understood right, you have
the pump, some fittings, a reservoir?
So, you'd still need: radiator + radiator fans, CPU block, GPU block, fittings, tubing at least
if I'm not mistaken.
I recommend having a look at http://xtremerigs.net , they have some pretty good radiator
and block reviews. EK seemed to be doing pretty well in the radiator department last I
checked, and their Vardar fans seem to be pretty decent too.
As for CPU blocks: It honestly doesn't matter all that much, the good ones are all pretty
close together. Pick one you like. Same for GPU blocks.
Tubing: There's hard tube and soft tubing to start with, each with their own upsides and
drawbacks, but neither really inherently superior. Obviously your choice of fittings will
also depend on this.
Figure out whether you want to do hard or soft tubing. Both are feasible, even for a
beginner, you'll probably just need a few extra feet of tubing for getting the hang of it
if you go hard tubing. Soft is easier, but hard tubing isn't impossible, just takes some
patience and a bit of practice. There's plenty of tutorials around. Aside from that you
also need to figure out how you want to route your loop, we can't really do that for you,
and then you'll know which fittings to use where (angles, 45, straight).
thank you so much for you advice here i tried to do my first plan sorry if a made a mistake i dont know anything in the watercoolin loop world sorry :P
i think i will go with hard tubing since its look more classy and sobre :D
P.S : i have a EK 4.0 pump , some fittings, and an alphacool reservoir yes
post-247427-0-06427500-1437950420_thumb.
Loop order: The one thing which actually matters is having the pump below the reservoir
so that when you fill it up the fluid can easily flow into the pump due to gravity. It's
not strictly speaking absolutely necessary, but anything else is a pain in the rear end.
The rest is just a matter of aesthetics and convenience.
As for parts: That will depend on where you buy and what is available. For radiators
you can have a look at the website I linked, see which ones perform well and if one of
those is available where you intend to shop. And as said, the Vardar fans seem to be
doing pretty well, although there are alternatives if you don't like those.
What fittings do you already have? Are they for hard tubing already? Because if not,
you'll need to buy new ones. Primochill, Monsoon, EK and Bitspower all make hardline
fittings, but they are not necessarily all compatible with each other. So you need
to pick one system and then buy the correc tubing for that.
Also, I wouldn't necessarily rush things with ordering, despite the discount. Better
if you figure things out first properly and do your research rather than ordering
the wrong thing IMHO. Ordering the wrong thing with discount will probably be more
expensive than ordering the right thing without discount. I did several weeks of
research back in the day before placing my first water cooling order (okay, I had
less help, but still, you get what I mean).
Hello guys,
Last idea parts :
EK Water Blocks - WaterBlock CPU EK-SUPREMACY EVO - Full Nickel (Original CSQ)
Phobya - Radiateur G-Changer 360 HP (Will this fit in my H440 with the 3 Fans ) ?
EK Water Blocks - WaterBlock VGA EK-FC TITAN X - Nickel / Acetal
EK Water Blocks - Backplate for GeForce GTX TITAN X NOIR
EK Water Blocks - Liquide EK-Ekoolant EVO red blood - 1 Litre
Alphacool - 10/13mm Plexi Transparent HardTube - 40cm
Pompe - EK-DCP 4.0
FAN - 3 x EK Vadar
Fittings - 6 right, 6 of 45° & one 90° (For both normal and hard tubbing)
Réservoir - Phobya Balancer 150 black
Sonde - Bitspower
here is my actual idea about the parts can you confirm if its good ?
For tubbing how much do i need to buy ? also i am watercooling the MotherBoard also so how much fitting do i need ?
i dont know how to place the pompe since its not a part of the reservoir so where can i put it to get the maximum performance and security for my rig ?
Unless somebody can personally check this, you'll need to find a review of the
case and see if they checked radiator thickness compatibility (that's usually
the limiting factor).
Can you give links to the fittings, makes it easier to check them out. ;)
The amount of tubing is determined by your loop layout, so I recommend taking out
a measuring tape and figuring out an approximate total length. Then add maybe 1 to
1.5 extra meters for beginner's margin when you screw up a pipe bend (I'm assuming
you're indenting to bend the pipe?). Also, if you do the pipe bending thing, you'll
need a heat gun (should be available at your local DIY store for not too much money).
Well, each block needs to fittings (one in, one out), plus the pump and reservoir,
so just count how many blocks and you should have the number of fittings. Whether
you need angled or straight (or 45) you need to figure out based on tube routing.
If you can afford it and are unsure, you can always buy a few more different fittings
to have a bit more freedom in trying out various versions.
Doesn't matter where you place the pump with regards to performance. The one
thing which matter is that it's placed below the reservoir, as said above, so
that filling the loop is easy. But that's it.
You might want go buy a pump decoupling kit if you haven't already, something
like this:
http://www.aquatuning.ch/wasserkuehlung/pumpen/pumpenentkopplung/15991/aquacomputer-shoggy-sandwich-bausatz-zur-pumpenentkopplung-version-2.0-schwarze-ausfuehrung?c=2977
or
http://www.aquatuning.ch/wasserkuehlung/pumpen/pumpenentkopplung/12926/aquacomputer-entkopplungsset-zur-pumpenbefestigung-extraweiche-gelbe-gummipuffer?c=2977
That way, the pump's vibrations don't transfer to the case as much and things
are significantly quieter.
Looks good in general though.
Hello guys,
Last idea parts :
Pompe - EK-DCP 4.0
FAN - 3 x EK Vadar
Sonde - Bitspower
For your rad it will probably fit, but that's dependent on the rad itself since they are all different sizes (for instance it NZXT says you can fix 3x120 (or 360mm) Rad in the top, but it doesn't say how thick it can be.
Your going to need 2 fittings per component (minimum this doesn't include angled adapters if you go that route).  Other then that it all looks pretty good, EK makes good stuff, just remember to double check your tubing/fitting sizes to make sure they are compatible.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
i notice that my case isn't open from the top so do i need to mod it or it will be fine event closed ?
It has vent holes on the sides of the top cover, not sure if they work as good as just a normal grill on the top though.
hope its work well :D
so are the fitting good for a hard tubbing loop ?
Those are compression fittings for soft tubing. You will need this for hardline: http://www.performance-pcs.com/rigid-revolver-compression-g1-4-fitting-to-3-8-x-1-2-straight-knurled-coupler-anodized-black.html
are you sure those will not fit for hard tubbing ?
yes, 2 very different types of fitting they are in no way interchangeable.
so i guess i have to buy another fittings what do you advice me to buy ?
The link I sent you a couple of posts ago are the same kind JayzTwoCents has in Skunkworks (if you know what I am talking about). You can look for others like it though. Make sure the fittings fit your tubing size though. This link has some: http://www.performance-pcs.com/catalogsearch/result/?q=dline+fittings
Hello guys i just received my pay :P so today is the day :D
i decided to go soft tubbing because i dont have the patience either the materiel to do it and since its my first water i dont wanna miss it up !
so here my last basket:
EK Water Blocks - WaterBlock CPU EK-SUPREMACY EVO - Plexi (Original CSQ)
Phobya - Radiateur G-Changer 360 HP (Will this fit in my H440 with the 3 Fans ) Up to 28/36 cm radiator from the NZXT website ?
EK Water Blocks - Liquide EK-Ekoolant EVO red blood - 1 Litre ( I want the same color in the picture below)
Alphacool - Souple TubbingTransparent 10/13mm (3m) (is it enough ?) ( CPU+GPU+MB)
Pompe - EK-DCP 4.0
FAN - 3 x EK Vadar
Fittings - 6 right, 6 of 45° & one 90° (is it enough ?) ( CPU+GPU+MB)
Sonde - Bitspower
Wich thermal compound do you advice me to but for both the CPU and GPU ?
