Sleeved cables
Go to solution Solved by ClownFace1511,
I have seen that one. But they're not for sale anymore.. At least not in my country.
The 24pin is the most important at this moment..
You may have to ship it in from the us if you cant find them in norway. Also click where to buy and see if anything pops up in your area.
HI, I'm considering buying some sleeved cables... But I'm not sure if they will be compatible with my AX1200(This is the one without the "I" in the name).
Power supply: http://www.corsair.com/en/professional-series-gold-ax1200-80-plus-gold-certified-fully-modular-power-supply
- http://www.corsair.com/en/professional-individually-sleeved-dc-cable-kit-type-3-generation-2-red
http://www.corsair.com/se-fi/individually-sleeved-ax-860-760-atx-24pin-generation-2-red
Will these work with the AX1200?
https://linustechtips.com/topic/415016-sleeved-cables/
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
https://linustechtips.com/topic/415016-sleeved-cables/#findComment-5583805
https://linustechtips.com/topic/415016-sleeved-cables/#findComment-5583814
https://linustechtips.com/topic/415016-sleeved-cables/#findComment-5583819
I guess I have.. I might just have found some in the UK.
I did try the "where to buy", but they redirect me to a site that tells me they don't have it anymore.
But anyway thanks!
https://linustechtips.com/topic/415016-sleeved-cables/#findComment-5583826
