hay i have been thinking on buying a computer for a long time and i need help finding out something hear is the link for a website im using to buy and computer but i dont know much about pc gaming because i have been a console gamer all my life. but will this build be able to play dayz standalone on good settings ? i need some one who knows this type of stuff's help pleas :) but if not that's okay really http://www.custompc.ie/index.asp?function=CART
https://linustechtips.com/topic/414798-pleas-help-me-with-this/
Link * sorry i said like :P
there's an Edit option, you don't have to create new posts every time to correct a type. saying this because its seems you're new.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/414798-pleas-help-me-with-this/#findComment-5581028
yea i am new :P and can you check that link pleas and then reload it when you are in it to see the build and can you tell me if it would run dayz standalone  on good settings ?
https://linustechtips.com/topic/414798-pleas-help-me-with-this/#findComment-5581053
what is your budget ?
PCPartPicker
https://linustechtips.com/topic/414798-pleas-help-me-with-this/#findComment-5581065
I just wanted to chime in here and say that I have to drop a lot of settings for DayZ to get consistent 60 fps at 1080p, and I'm running a 980 ti, i73820, and 16 gbs of ram.  The only reason I'm bringing this up is to say that the game is honestly just terribly optimized at this time, and I wouldn't recommend basing the foundation of any machine configuration off of it's ability to play a badly optimized game.  I truly believe a 750 ti would run DayZ at a level not too far from my 980 ti, so if that game's the only reason that you're building this rig then I would recommend not going with an expensive machine as I expect optimization for that title to improve a lot in the future.  That being said if you're still interested in building a more capable machine and are interested in games other than DayZ then you have a budget that can build a machine capable of beasting 1080p at max settings, assuming you end up going with an i5/970 or r9 290.  Also, just so you know bro that website's sketch as f*ck, don't believe I'd use that my man.  Just my opinion though.
Oh signature time!  It's on now, gonna give ya somethin snarky and clever and think way too hard about this because I'm really concerned about what people on the internet think of me.  Better google some good quotes to put in here too.....oh wait I'm not a loser.
https://linustechtips.com/topic/414798-pleas-help-me-with-this/#findComment-5581859
Get an i5 4690 with a gtx 970, and at least 8gb of RAM and you'll be fine. Although I prefer to recommend 16gb of RAM because: reasons
Dubs are better than subs
https://linustechtips.com/topic/414798-pleas-help-me-with-this/#findComment-5581863
