Need an Amplifier ASAP
I have a left and right speaker system that needs an amplifier. I would love to plug in a headset and microphone as well if possible but whatever works. I have a subwoofer but it has a built in amp so i only need Left + Right. Looking for something extremely cheap. MAX INPUT PWR 75W each.
https://linustechtips.com/topic/414182-need-an-amplifier-asap/
Here's something cheap, not sure of the exact specs of your speakers but these will drive anything above 4ohm. Might not allow your speakers to go all the way up to 75w but I am sure it can do at least half of that.
http://www.amazon.com/gp/product/B0049P6OTI/ref=olp_product_details?&ie=UTF8&me=
https://linustechtips.com/topic/414182-need-an-amplifier-asap/#findComment-5572428
I have seen that but I'm wondering if this works?
http://www.amazon.com/gp/product/B003OELGGG?psc=1&redirect=true&ref_=ox_sc_act_title_4&smid=ATVPDKIKX0DER
My speakers are 8 OHMS and 75 W each.
https://linustechtips.com/topic/414182-need-an-amplifier-asap/#findComment-5572598
Yeah I am not an expert mate, it should work as 8 ohms is less of a load compared to 4 ohms.
I'd spend a bit more and get something that doesn't look like it belongs in a car.
http://www.amazon.com/SMSL-50Wx2-TDA7492-Amplifier-Adapter/dp/B00F0H8TOC
Even at 50w capacity, I doubt you will ever hit 25wats in a small room, because I never do with my speakers which are 6 ohm 100w
https://linustechtips.com/topic/414182-need-an-amplifier-asap/#findComment-5573073
I have a question for you. I really could use help. I made a new post for wiring audio that i would like for you to answer.
http://linustechtips.com/main/topic/414225-need-some-serious-help-wiring-a-system/
https://linustechtips.com/topic/414182-need-an-amplifier-asap/#findComment-5573140
