88 key ISO Fin/Swe, Help me find please.
mcmxcii
Hello,
I am looking for a new keyboard. I have a few things that I want the keyboard to have. It would be great if any of you guys knew of any keyboards that would fit into my needs.
My needs.
10 keyless desgin.
ISO design Enter/return key
Finnish layout (öäå)
Back lighting
Mechanical: Browns
I want it to be well made, no cheap plastic stuff.
I was looking at some WASD keyboards, they had one that seemed perfect but just wasn't backlite. http://www.wasdkeyboards.com/index.php/wasd-v2-88-key-iso-custom-mechanical-keyboard.html
If anyone can help it would be good.
CM Storm Rapid-i and Ducky Shine tenkeyless are probably your best options. Quite easy to find even in nordic layout.
I really don't like the idea of having removable cables, it's just asking to break. and there is just no need for it.
That's kind of the strength of removable cables: if it breaks, you only have to replace the cable instead of whole board. Also makes portability a lot easier, and not a real issue if you don't move the keyboard.
I can only think that the tension on the socket will cause a higher chance of it break, that just having a fixed one.
