Trying to Learn how speaker systems work... HELP!
Oh... I see^^ The subwoofer is only a speaker, it's no amplifier. It has these four ports so you can loop it in between an amplifier and the speakers. So you connect those two wires to an amplifier and then to the 'High level in" on the sub. It will then filter out everything below a given frequency (which you can set with the frequency nob there) and pass everything above out the "High level out". You can take a second pair of wires and connect the speakers just how you did there. This way, you can use the sub without having an amplifier with a dedicated "subwoofer out" port.
The way you have it set up, only the sub should work. However, it cannot output the signal it receives through the "low level input" because this is the port where a signal already only containing the "information" for the low channel ", e.g. the .1 in 5.1, but it cannot amplify it for the two front speakers.
Nonetheless, you already have most of the parts. You only need an amplifier and due to the possibility to loop the sub in, it does not even necessarily need a SubOut port. You said something about a Pioneer?
You can see the wiring in this picture:
Would you say the dayton sub is better than something like a polk pws10 or are they around the same as far as clarity and sound range goes. Just asking since they are around the same price and I'm considering upgrading my current speaker system
I have a JVC amp that would work but it's literally huge and heavy. I feel like it's overkill but if I was to use this amp can I set it on the carpet? If not where is a good place to put it?Would you say the dayton sub is better than something like a polk pws10 or are they around the same as far as clarity and sound range goes. Just asking since they are around the same price and I'm considering upgrading my current speaker system
Are there any smaller, cheaper amps to power the two left and right speakers? Not looking to spend very much. It would be cool to get an amp that can power left and right + a desk studio type microphone. Also how can I have my speakers working and my headset plugged in?
