Computer not working! Help!
Go to solution Solved by Knaj,
Problems all solved now! Thanks guys!
Everything in the system is powering on, PSU, all the fans, LEDs, everything, but when I try to connect it to my TV it isn't working! I even tried connecting it with a different monitor and it didn't work! I tried multiple cables, and it's not working!
Faulty CPU maybe..?
Please help ASAP!
https://linustechtips.com/topic/413849-computer-not-working-help/
Plug in the speaker that should've come with your mobo and tell us the code, or look at the screen on the mobo, if it has one, and tell us the number
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
Faulty CPU maybe..?
Please help ASAP!
Even if the cpu was bad it should still boot to bios i believe.
when it comes to the display ports are you using the ones on the motherboard or on the graphics card? you have to plug display ports into the graphics card
even if there are no drivers?
make sure your gpu is seated properly. make sure there is power going to the motherboard. check every cable to make sure they're plugged in properly. try getting the pc to boot with your monitor only first.
For the CPU connector there wasn't an 8 pin so I just used a 4+4 pin, does that work or do I need to use the 6+2 pin?
I have a XFX 750w TS psu
